Ansys Products
Ansys Products
CFD-Post malfunction
    • OceanZhou
      I've run Fluent successfully and a solution was achieved. However, when I try to open up Post-process through CFD-Post, this screen appears and I'm not able to open up CFD-Post:
      Any ideas on what to do?
      Short term use the post processing in Fluent. I'll move this to installation for a longer term fix.
    • tsiriaks
      What is the output of the following command from CMD Prompt
      dir /s "c:*libcuemonitordata*"
      Do you have an install.err file under (default)
      C:Program FilesANSYS IncANSYS Student
    • OceanZhou
      Hi tsiriaks,
      Thank you so much for replying!
      I do have an "install" file under the ANSYS Student folder. However there is no install.err file.
      This is what appears when I enter as you instructed.
      Best,
      Ocean
    • tsiriaks
      It seems you are missing
      ANSYS Incv201CFD-Postlibwinnt-amd64libCUEMonitorData.dll
      which is where I believe the tool is looking for.
      Do you have this folder at all ANSYS Incv201CFD-Post  ?
      Try this. Close all ANSYS applications, then run the following with 'run as administrator'
      ANSYS Incv201ProductConfig.exe
      select Uncofigure products and select all of them to unconfigure it
      once that's done, select Configure products and select all to reconfigure them
      Thanks,
      Win
Viewing 4 reply threads
