Tagged: animation, cfd-post, sliding-mesh, transient-analysis
February 23, 2022 at 7:14 am
MadScientist
SubscriberFebruary 23, 2022 at 7:19 amDrAmine
Ansys EmployeeI will rather user default export to CFD-Post and just export case file every time you try to write data: stick to this for couple of time step to see if it helps.
That warning in CFD-Post is telling that it cannot understand your parameter regarding angular velocity and all that stuff so it will had some issues translating the relative velocities.
Are you using actual release?
Is Fluent Post-Processing not enough to have good animations?
February 23, 2022 at 7:28 amMadScientist
SubscriberWhat do you mean by default export? Is it the final file Fluent exports at the end of the simulation?
I saw that I had not exported Relative velocities in the Automatic Export Dialog, but I had exported the Mesh Velocities. Could this be the problem?
Actual Release? Yes, this is not the Student Version. It's the Enterprise version that we have bought!
Fluent Post Processing requires me to know beforehand what I want to animate so that I can define the scenes beforehand, right? I just wanted to get as much data as possible and animate all of them to see visually the trends. This is why I was exporting to CFD-Post.
February 23, 2022 at 8:37 amDrAmine
Ansys EmployeeDefault export: writing a case file every time you write a data file.
As you are commercial customer: can you please get in touch with your local Ansys Support using Customer Portal?
Trending discussions
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
