CFD Post processing error
    • PhilippM
      hello all,
      I am trying to investigate the hydromechanical properties of joints as part of a lecture at university. Im using Ansys student 2021 R1.
      I have simplified this problem by using a measuring cylinder with an open outlet (in the form of a joint) at the bottom. In Ansys I have used the system "Fluid dynamic (Fluent)". However, at the end of the simulation I cannot open my results in "CFD Post Processing". I get the following error messages (a screenshot is in the attachment):
      • Error reading file XXXXX.dat.h5'
      • Error opening file XXXXX.cas'
      • The results reader couldn´t be initialized
      Does someone have an idea how I can fix this and display my results ? Thank you for your efforts!
      Best,
      Philipp
    • Keyur Kanade
      As ANSYS Staff, we can not download attachments. Please upload images using upload image functionality.
      Please export .cdat file from Fluent and then read it in CFD-Post.
      Or you can use write .cas and .dat files from Fluent to read them in CFD-Post.
      Regards Keyur
    • PhilippM
      Hallo Keyur,
      ty for your fast replay. I already tried to input the result files by hand by using the "load Results" button in CFD-Post and choose the result data file. But it still shows me the same error message. I┬┤ll put you an image of the error type in here. Ty for your help!
      regards,
      Philipp
    • Olnjiko
      I have the same issue.
    • a1055246
      I have the same issue. Has anyone solved it please?
Viewing 4 reply threads
