CFD post-processing
    • JASOMCHANG
      Hello everyone, I have some problems in CFD post-processing. The following figure shows the result of the calculation?Calculated result This is at timestep 19
    • Surya Deb
      Hello, nCan you please check the Scales on the Contour. The 1st contour has different scales than the 2nd and the 3rd. nIf so, then please change the scale accordingly. The 1st and the 3rd should have same/similar scales.nRegards,nSuryan
    • JASOMCHANG
      Hello i using of contours is 11nThe 1st contour and 2nd and 3rd are use contours is 11nBut the result is the samenn
    • Surya Deb
      Can you please change from Global to Local Range and check it ?n
    • JASOMCHANG
      Thank you, the problem is solvednn
Viewing 4 reply threads
