CFD-Post streamlines
    • iainb
      Hello everyone. I have a problem and I am wondering if anyone can help me.
      I have a simulation set up where I have a rotating arm inside a hexagonal enclosure. The simulation is set up with a turbulent model with air as the fluid. I created a Boolean around the arm (Boolean 1) and then another Boolean (Boolean 2) around the first Boolean. Boolean 1 is the cylinder and Boolean 2 is the hexagonal enclosure. Boolean 2 is set as the enclosure and has no inlets or outlets. My aim for the simulation is to show (with streamlines or vectors) the airflow around the arm as it rotates.
      My issue is that in order to generate streamlines I need to specify a start point. If I do this then the streamlines will flow from that point forwards or backwards which will bounce off the enclosure walls and look messy. What I want is to show the arm moving and the streamlines moving round the arm as it moves. I am curious if this is possible and how I would go about setting it up?
      The max speed of the arm will be around 150m/s. I know the pictures show the speed is higher but this is just a test.
      Cheers,
      Iain
    • Keyur Kanade
      Can you please insert images?
      Some basics can be found at
    • DrAmine
      You might visualize vectors or create the streamline out of of point cloud.
    • iainb
      Hey Amine,
      Thanks. The vectors do show air flow better. Do you know if it is possible to create an animation of the vectors travelling over the arm as it is rotating?
      Cheers,
      Iain
    • Keyur Kanade
      Check this.
    • iainb
      Thanks guys
Viewing 5 reply threads
