CFD Pressure XY Plot
    • learn13
      In the attached picture is the pressure results along the length of a 2D channel with a bump on the bottom wall.
      I'd like to obtain similar plots but from a 3D model.  I'm thinking I'll have to define a place and get the results I'm after that's akin to the 2D data.
      I'd appreciate any help!
    • raul.raghav
      You can create a line in CFD-Post and plot the Pressure vs Length graph. Refer the following youtube video for reference:
      Skin Friction Coefficient along a Line
    • Vishal Ganore
      Define a plane under your 3D model, and plot the pressure contours.
      Good option Rahul regarding plot but looks like lean 13 need a line with a bump in the middle to plot the data on that line. In that case, only creating a line may not help.
      I assume your 3d model would be symmetric and you would be able to select and name your required edge under ANSYS meshing to pull the line with a name under Fluent for selection. Once done, proceed for plot under Fluent.
