CFD simulation of ambu bag
    • Riteishp333
      Trying to simulate a flow through balloon where inlet flow rate is 15 lpm and outlet is 60lpm, what I need to understand is how much residual volume is left when 60 lpm is sucked out of the domain, what approach should be used to do this, dynamic meshing is crucial correct?
      What setting s I should use so that the walls of balloon deform and inflate as per the flow?
      Any help is appreciated, just need direction on how I can simulate this case.
Viewing 0 reply threads
