August 30, 2018 at 4:21 am
Jovi_boy
SubscriberHi, I am fairly new to ANSYS (I've looked at a LOT of sources and tutorials) and want to simulate flow around a boat hull while also acquiring useful data (drag, straight line ability of my boat, and maneuverability) so I can optimize my boat. I still have no clue as to how to do this and how I can get data from it. My general method is to create 2 groups (air and water) and have those volumes be cut in by the shape of my boat (I'll have empty space where the boat should go). From here I have no idea what to do. I have consulted these sources:
https://drive.google.com/file/d/0BxWAqiVfkTWMOGRkODViMDMtY2VmZC00NjRlLTg3MDEtMDQ0NTE4MjNkZGJl/view?hl=en
and https://digitalcommons.cedarville.edu/cgi/viewcontent.cgi?article=1092&context=research_scholarship_symposium
I've been using VOF to simulate air and water, but I really have no idea what plugging in certain numbers and options does. I would really appreciate it if someone could reference me to a definitive tutorial for this. I've been trying to figure this out for a month now to no avail. Should I even use the fluent option?
August 30, 2018 at 10:56 am
Ansys EmployeeShort answer is yes, Fluent is the correct tool.
Have a look in the documentation for the Open Channel Flow (it's a special option for VOF), and take it from there. For simplicity I'd suggest fixing the ship in place rather than trying to move it!
September 3, 2018 at 9:56 pm
Raef.Kobeissi
Subscriberyou will need to use 6 DOF model in order to simulate this model with the open channel and wave model (VOF). It is doable. I will try to make a tutorial about it soon! Briefly, the boat will have to be assigned as a rigid and it should be surrounded by a sphere or a box that will deform, the whole lot will need separate UDF files to assign their moment of inertias.
September 4, 2018 at 2:08 am
Keyur Kanade
Ansys EmployeeHi,
There are many tut available online for vof in fluent. I would say start with 2D.
Keyur
September 5, 2018 at 3:48 am
Jovi_boy
SubscriberBy fixing it in place do you mean I should have my boat be cut into my volume domain or that my boat should exist inside of the domain as a separate body?
November 13, 2018 at 12:17 am
Kevinsandoval
SubscriberHola , solucionaste el problema? tengo que hacer lo mismo , simular la estabilidad del buque , tengo pensado en hacerlo con VOF y malla dinamica aplicando el modelo 6dof , voy por buen camino? agradecería sus comentarios
November 13, 2018 at 12:34 am
August 9, 2020 at 12:09 am
Alishah
SubscriberSir did you make any tutorial on dynamic mesh of boat so far. If yes please give me link. I need urgent help. Thanksn
2600
2088
1319
1108
459
