June 26, 2019 at 3:11 pm
StacyLab
SubscriberHi!
I need to select a good workstation for CFD modeling in ANSYS for my Lab to buy.
I understand that there's 25-40% decrease in simulation performances if all memory slots are not filled with the same amount of memory. - The specs of a DELL workstation option are listed below. I have 2 quick questions related to RAM choice:
1. Are 64GB (8x8GB) or 96GB (4x16GB + 4x8GB additional sticks) valid options?
Or is it worth to consider reducing the cores number (for instance, 8C instead of 10C) and invest in larger RAM (8x16GB=128GB, for instance)?
2. Do I really need 192GB of RAM to match the minimum memory requirement?
Budget is ~ $6-7k. The workstation is needed for time-dependent, rigid-wall simulations (2M element mesh). As reference, I used to run these simulations on *2 CPU of 8 cores each (DELL Intel Xeon CPU 2650 0 @ 2.0 GHz), 64 GB of RAM, and 2 HHDs of 2TB each*. - The simulation would run for 2-3cycles in 4-6days.
Thanks a lot in advance for your help!
____________________________________
Full specs (DELL Precision 5820 Tower):
Intel Xeon W-2115 (3.3GHz, 4.5 GHz Turbo, 10 Cores, 13.75MB Cache)
64-96 GB RAM
INVIDIA video card P4000 (8GB, 4 Displayport 1.4)
Operating System: Windows 10 Pro
Precision 5820 Tower 950 Chassis
Hard Drive Controllers: Integrated Intel AHCI SATA chipset controller (8x 6.0Gb/s), SW RAID 0,1,5,10
Hard Drive: 2.5” 512GB SATA SSD
2nd Hard Drive: 2.5” 1T SATA SSD
3rd Hard Drive: 2.5” 1T SATA SSD
*edited for clarity - apologize for confusion*
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5364
3363
2471
1310
1018
