March 2, 2022 at 2:43 am
francokew
SubscriberHi, I am working on flow pattern where I create 2 parts. The first part is build with "Fill" and with outlet on the top side. The second part is an "Enclosure" with opening as inlet. Both parts are fluid - water as shown in first photo.
March 4, 2022 at 1:30 amSurya Deb
Ansys EmployeeHello,
Can you make sure if the 2 parts created are connected to each other?
Do you see any warnings for isolated regions in CFX out file?
Regards SD
March 4, 2022 at 9:46 amfrancokew
SubscriberHello Sdeb I have proceed the following steps:
Insert - Solver - Expert Parameter - Convergence Control - check isolated regions value = t and ticked. The result is similar as before, and there is no warning message.
Regards, Fran
2524
2066
1279
1096
457
