CFX Anisotropic/Algebraic Turbulent Heat Flux
    • donmohsen
      Hello the community I have found that for implementing user defined anisotropic turbulent heat flux closure you can do it by editing ccl file like below:
      CFX 2021,R2
      FLOW:
      DOMAIN: Domain 1
      FLUID MODELS:
      HEAT TRANSFER MODEL:
      Option = Thermal Energy
      TURBULENT FLUX CLOSURE:
      Option = User Defined
      uh = 1. [m^3 s^-3]
      vh = 2. [m^3 s^-3]
      wh = 3. [m^3 s^-3]
      END
      END
      END
      END
      END
      But when i run this ccl, it says there is no 'user defined' option available.
      Can somebody help me please??
      By the Way I wanted to Implement algebraic turbulent heat flux equation in CFX. I would be happy for any help.
      Thanks
    • Surya Deb
      What is the turbulence model that you are using? Are you using SSG Reynolds Stress model?
      Anisotropic diffusion is not available for all turbulence models.
      SD
    • rfblumen
      The CCL that you're referring to was a beta feature in CFX-5.7 (2004).  A lot has changed in the software since then and this beta feature is no longer available.
