November 16, 2018 at 4:01 pm
CatiaV5
SubscriberHi all,
I have created a mesh in ICEM and ensured via moving all visible nodes on the symmetry plane to z=0 that they are indeed all on the symmetry plane.
However, my simulations keep exiting with an error stating that the symmetry plane is not a strict plane. I'm reluctant to change the expert parameter as this would affect my solution but I have no idea why this keeps happening or what else I can do in ICEM to solve this issue.
Can anyone help out please?
November 16, 2018 at 4:41 pm
DrAmine
Ansys EmployeePerhaps you have two side faces in the same boundary part. In ICEM you will need to separate them into two separate named boundaries and then set them as separate symmetry planes
November 16, 2018 at 5:50 pm
CatiaV5
SubscriberThe thing is with a higher value for 1st layer height I didn’t have the issue. Now that I have changed the value to something smaller the symmetry plane is not planar anymore.
Can it be linked to having to little overall elements now?
Or too many or too few associations?
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2508
2064
1277
1088
456
