February 23, 2022 at 9:35 pm
denzel
SubscriberHi,
By opening the tool Solver Manager I get the message that the file "libCUESMCCLHandlingQt.dll" could not be found.
I tried to reinstall but still get the same message. Everything else works perfectly fine.
Would somebody know, how to solve this problem?
Thanks,
Denzel
March 3, 2022 at 9:35 pmGeorge Karnos
Ansys EmployeeDoes the dll file exist under:
C:\Program Files\ANSYS Inc\ANSYS Student\v212\commonfiles\CFX\lib\winnt-amd64
What is the output from running the following in a dis command prompt window:
set PATH>set.txt
post the contents of the file set.txt as we are not permitted to open files.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2726
2156
1359
1150
462
