Ansys Products
Ansys Products
CFX with EPYC 7742 problem with Windows server!
    • Hyun shin
      I am using ANSYS 2023 CFX in Windows server.
      When I summit job, CFX does not work sometimes.
      So I changed the machine From AMD 7742 to Intel CPU Server!
      then The problem is solved!
      I think CFX has some problem with AMD EPYC 7742.
      More detaily, Intel MPI 2018 version has some problems with AMD 7742 CPU!
      I want to know how to sovle the problem!
      Can I change CFX's Intel MPI version in Workbench environment?
    • rfblumen
      There have been a couple of reported cases related to this processor with Intel MPI.  It's under investigation.  In the mean time, please try using the "Microsoft MPI local parallel" option for running parallel.
      • Hyun shin
        Thanks your reply!
        I think you know the performance of MSMPI is very very poor!
        So I can’t use MS-MPI!
        Linux OS version use more later version of Intel MPI than Windows!
        So I think ANSYS already knew the bug about Intel MPI with 7742 CPU.
        But You did not make any modifications!
        I hope ANSYS makes new version of CFX using new INTEL MPI!
        Can you give me the schedule for solving this bug?
        How long should I wait for the solution?
        If you need my help about solving the problem, contact me any time!
      • Hyun shin
        When can I get the solution about Intel MPI ?
        I used over 100 thousand dollars in my server about 2.5 years ago!
        But the server has been just idling with cosuming electricity!
        ANSYS must show responsibility with this problem!
