[CFX][Setup] Cyl. Vel. Components
    • betteroden
      I have 3 inlet fans spinning at 1500 RPM ( =25 Rounds Per Seconds )
      Pushing 250 [m^3/h] { 250/(60*60) *1.204 ~ 0.084 kg/s }
      "1.204 is the air dencity at 20 degrees C"
      I have 3 Coordinate systems, one for each fan!
      I just want to understand what values are required for:
      Axial component
      Radial Component
      Theta Component
      Is axial the velocity of the outer edge of the fan?
      Radial should be 0
      Theta is radians per second for the outer edge of the fan?
      Thank you in advance :)
    • betteroden
      Also what isninlet 1.1ninlet 1.2ninlet 1.3nis it:ninlet 1.1 = xninlet 1.2 = yninlet 1.3 = zn
    • DrAmine
      If you have already defined your local coordinate systems why not directly using them in the boundary specification?n
    • betteroden
      If you have already defined your local coordinate systems why not directly using them in the boundary specification?https://forum.ansys.com/discussion/comment/98365#Comment_98365
      No idea what you mean !nI want to know:nn' Axial componentnRadial ComponentnTheta ComponentnIs axial the velocity of the outer edge of the fan?nRadial should be 0nTheta is radians per second for the outer edge of the fan? 'nnandnn' Also what isninlet 1.1ninlet 1.2ninlet 1.3nis it:ninlet 1.1 = xninlet 1.2 = yninlet 1.3 = z 'nnEdit*nI can not find a single place on the internet that talks about those! n
    • DrAmine
      1.3 will correspond to the local z axis. So that will be your local axis of rotation.n
    • betteroden
      1.3 will correspond to the "local z" axis. So that will be your local axis of rotation.https://forum.ansys.com/discussion/comment/98399#Comment_98399
      thank you, now I have one question answered !nOne to go!n
    • betteroden
      Bump :(n
    • DrAmine
      Theta Velocity Component is the velocity component in circumferential direction and this is meter per second: Velocity dimension.n
    • betteroden
      Theta Velocity Component is the velocity component in circumferential direction and this is meter per second: Velocity dimension.https://forum.ansys.com/discussion/comment/98558#Comment_98558
      that's the Axial component! nif not then the axial and theta is the same!!!n
    • DrAmine
      https://forum.ansys.com/discussion/comment/98558#Comment_98558that's the Axial component! if not then the axial and theta is the same!!!https://forum.ansys.com/discussion/comment/98858#Comment_98858
      ?n
Viewing 9 reply threads
