December 15, 2022 at 5:07 pm
William Grissom
SubscriberHi, I have been issued a license by Ansys in a file called 'LSTC_winlic.txt' which I have tried to use without success. It appears to give access to MPPDYNA (Option: Revision 13), MPPDYNA_971 (Option: Revision 6), MPPDYNA_970, MPPDYNA_960, LS-DYNA (Option: Revision 13), LS-DYNA_971 (Option: Revision 6), LS-DYNA_970, and LS-DYNA_960. It lists a key at the bottom and at the top it lists 40-digit SERVER and additional 'Interfaces'. I have tried unsuccessfully to run LS-DYNA of various versions (the key appears to let me use MPP or SMP versions 13 or 6 so I have been trying 13 smp and mpp, but also 12). I have tried running it both from LS-RUN after loading in the license, and from the command line after checking that the two environment variables point to the local license. However I always get the same 'Error Bad license keys!' message in my output/log. I must be missing something? Below is an example output.
Thanks,
Will Grissom
License option : check local license only
* ANSYS 2021 R1 LEGAL NOTICES *
* Copyright 1971-2021 ANSYS, Inc. All rights reserved. *
* Unauthorized use, distribution or duplication is *
* prohibited. *
* Ansys is a registered trademark of ANSYS, Inc. or its *
* subsidiaries in the United States or other countries. *
* See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
* documentation CD or online help for the complete Legal *
* Notice. *
* THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION *
* INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY *
* PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS. *
* The software products and documentation are furnished by *
* ANSYS, Inc. or its subsidiaries under a software license *
* agreement that contains provisions concerning *
* non-disclosure, copying, length and nature of use, *
* compliance with exporting laws, warranties, disclaimers, *
* limitations of liability, and remedies, and other *
* provisions. The software products and documentation may be *
* used, disclosed, transferred, or copied only in accordance *
* with the terms and conditions of that software license *
* agreement. *
* ANSYS, Inc. is a UL registered *
* ISO 9001:2015 company. *
* This product is subject to U.S. laws governing export and *
* re-export. *
* For U.S. Government users, except as specifically granted *
* by the ANSYS, Inc. software license agreement, the use, *
* duplication, or disclosure by the United States Government *
* is subject to restrictions stated in the ANSYS, Inc. *
* software license agreement and FAR 12.212 (for non-DOD *
* licenses). *
***************************************************************Date: 12/09/2022 Time: 13:00:16
___________________________________________________
| Livermore Software Technology, LLC |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Date : 08/10/2021 Time: 17:03:01 |
| Version : smp s |
| Revision: R13.0-365-gf8a97bda2a |
| Features enabled in this version: |
| Shared Memory Parallel |
| FFTW (multi-dimensional FFTW Library) |
| Interactive Graphics |
| ANSYSLIC enabled |
| MADYMO indirect coupling (7.2 or higher) |
| Licensed to: |
| Platform : WINDOWS X64 (SSE2) |
| OS Level : Windows 8/10 & Srv 2016/2019 uum |
| Compiler : Intel Fortran XE 2019 MSVC++ 2019 |
| Hostname : DESKTOP-CFDHIHU |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
*** License problem ***
Local license:*** Error Bad license keys!
*** Error 70022 (OTH+22)
Please file a Service Request (SR) via the ANSYS Customer
Portal at https://support.ansys.com.
Customers using an academic license may seek assistance
at https://forum.ansys.comE r r o r t e r m i n a t i o n
December 19, 2022 at 5:09 pm
Reno Genest
Ansys EmployeeHello,
We do not issue node locked licenses anymore; we only issue network licenses. Please set the following environment variable on the client machine:
LSTC_LICENSE=network
Also, the "Bad license keys" error is usually caused by one of the following:
- The license file was modified. The LSTC license file cannot be modified (change the text, etc.) or else the bad license key error will show up. Please use the original LSTC license file that was sent to you.
- You are using an older version of the LSTC license manager. The solution is to upgrade to the latest:
https://ftp.lstc.com/user/Download-Instructions/Job-License-Manager/
username: user
password: computer
Here is the LSTC license manager installation procedure for Windows:
https://ftp.lstc.com/user/license/License-Manager/LS-DYNA%20Win%20License%20Server%20installation%20and%20update%20Aug%2026_2.pdf
Here it is for Linux:
https://ftp.lstc.com/user/download-instructions/License-Manager/LSTC_LicenseManager-InstallationGuide.pdf
Finally, the following website will have most of the LS-DYNA resources:
https://lsdyna.ansys.com/
Let me know how it goes.
Reno.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2524
2066
1279
1096
457
