3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
Change axis cross section
    • Hoang NGUYEN
      Hello everyone,
      I would like to change the axis of the cross section ( change the axis X Y in the cross section on the photo ) so i can have the cylinder axis of an object as the axis of the cross section. Can anyone help me in this matter? Thank you and have a nice day
    • Devendra Badgujar
      Forum Moderator
      Hello Hoang,
      When you are in the section mode in SpaceClaim to see the cross section view, you can use the Move grid to translate/rotate the grid to required location.
      Devendra
    • Hoang NGUYEN
      Thank you for your reply. But i need to rotate the section so the plane of the section is the plane of cylinder coordinate system of an another model.
    • Devendra Badgujar
      Forum Moderator
      Hello Hoang,
      You can do this using the Move tool. Move tool can be used to translate or rotate to realign/reorient the geometry with another model.
      You can learn more about basics of Move command from this Discovery SpaceClaim: Getting Started Tutorials - Ansys Knowledge
      Devendra
Viewing 3 reply threads
