August 26, 2021 at 9:33 am
cujhg
SubscriberHi,
I used to use the free student version from Ansys. As I've run into the limitation of 512000 Nodes I want to switch to my university's academic licence. Is that possible or do I have to reinstall Ansys from the ground up?
Thanks,
Clemens
August 26, 2021 at 8:09 pmANSYS_MMadore
Ansys EmployeeYou will need to install the full Ansys package.
March 1, 2022 at 10:17 pmdrwatts9721
How can we go about installing the full Package? I also have the student version and would like to switch over to the full package. I cannot find any location on the website for installing the full package.
March 2, 2022 at 11:46 amRob
Ansys EmployeeThe full package is on the Customer Portal, https://support.ansys.com/Home/HomePage under downloads. You'll need to register, and if you have any problems please use the Help on there: we can't do anything from this side.
Please make sure you completely uninstall the Student version(s) from your machine BEFORE installing the full version. The licence managers do not work well together. You'll also need to either have a local licence or see the University system.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2656
2120
1349
1118
461
