Change graphics window size
    • kramer
      short question: Is there a menu or script command to change the size of the graphics window (at least for image export)? In some situations, the user may need to export a couple of images which should all be of the same size. If the size of the graphics window is changed accidentally (e. g. by increasing the size of a side bar), the size of the graphics window must be restored manually by dragging the borders, which can be tedious.
      If no such feature exists, it would be a good addition.
    • Lydia
      Dear Kramer,
      There is a way to store your layout. Go to Home toolbar--> User defined--> Store layout
      Hope this helps,
      Lydia
    • kramer
      Thank you. Can the window size also be set by scripting?
      • Lydia
        For this kind of questions you can address to https://developer.ansys.com/
