November 19, 2018 at 4:26 pm
csup26
SubscriberI am trying to create the following geometry of a D-Spar using layers of UD E-glass.
Front View of spar
Orthographic view of spar
I am using the following outer shell model to stack the layers going towards the center.
I am trying to guide myself with working through ACP for the first time and get stumped when I get to the change in thickness of the left, pointed side of the spar. The thickness of the stackup is 5mm up until that point. I am not sure how to model the thicker part. All I can assume is there is some layer staggering and tapering involved. If anyone could guide me to a tutorial on either of those, or explain it in the replies, it would be helpful. I have done google searches and haven't found anything.
November 19, 2018 at 5:03 pm
Sandeep Medikonda
Ansys EmployeeHi, You should be able to find a few examples when you installed ACP. Do you see this folder (ACP Examples) in the start menu:
I think Tutorial 2 in there is what you are looking for:
Additionally, please see this post.
Sandeep
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2706
2138
1355
1144
462
