August 9, 2023 at 2:28 pm
Tobias Zeller
SubscriberHey everyone,
I am trying to control the inflation layer on a mesh via a python script and got two problems.
My current code looks like this:Rotor_Inflation = mesh.AddInflation()
Rotor_Inflation.ScopingMethod = GeometryDefineByType.Component
Rotor_Inflation.NamedSelection = ExtAPI.DataModel.GetObjectsByName("Rotor_Face")[0]
Rotor_Inflation.InflationOption = 1
Rotor_Inflation.FirstLayerHeight = Quantity(0.4, "mm")
Rotor_Inflation.MaximumLayers = 15
Rotor_Inflation.NamedSelection = ExtAPI.DataModel.GetObjectsByName("Rotor_Aussenkante")[0]
Rotor_Inflation.Name = r"""Rotor_Inflation"""
Tree.Refresh()
mesh.GenerateMesh()I try to address everything via NameSelection, since I have already defined them in advance.
Now I have the first issue that in the second line "Rotor_Inflation.ScopingMethod = GeometryDefineByType.Component" I get the following output:
"Typenkonflikt. (Exception from HRESULT: 0x80020005 (DISP_E_TYPEMISMATCH))"
I would like to know if "Component" is wrong here or what else I should use?
My second question is, how do I change the "Boundary Scoping Method" as right now I'm using two times the same code (Line 3 and 7) and this is not working as well?Hope someone can help me out.
Best regards. -
August 11, 2023 at 1:43 pm
Nilay Pedram
SubscriberHello,
PyAnsys is currently a set of open-source projects . Questions on PyAnsys should go through the Developer Forum. Bug reports can be made by creating 'Issues' in GitHub.
Thanks.
4502
2961
1449
1322
