May 6, 2022 at 5:51 am
pluvianox
SubscriberHello,
I have a small issue with Design Modeler (or SpaceClaim) : it doesn't automatically change the metric system with the settings from Workbench Home pannel.
It is slightly annoying since I create a first sketch and I have to rescale it manually.
Thanks for your help,
May 9, 2022 at 3:38 pmRK
Ansys EmployeeHello,
Looks like you are not saving the workbench after you set the unit in workbench. Can you please set the unit in WB, save it and then open Design Modeler or SpaceClaim.
May 10, 2022 at 5:38 amMay 10, 2022 at 8:33 pmRK
Ansys EmployeeBefore you open any module in WB, please make sure you set the appropriate units and then start / load a module. It should work.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8740
4658
3151
1678
1452
