February 15, 2022 at 6:06 am
NataliaM
SubscriberHello!
How do I change the model user properties through the Lumerical script file?
Thank you
Natalia
February 15, 2022 at 5:43 pmGuilin Sun
Ansys EmployeeLike any other object, you can use this script to set the parameters:
setnamed("::model","aa",3); # "model" is a special object so it needs "::" before its name
If it is for group parameter, you can use
setnamed("group_name","var_name", value);
Please note that all values are in MKS unit in script by default, which is different from GUI where you can see/set derived units, such as um in length instead of meter, and fs instead of second.
The variables must exist before using the above script.
April 26, 2022 at 3:01 amfuduji
SubscriberThank you
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
8786
4658
3151
1680
1468
