Change of coefficient of thermal expansion does not change evaluated stresses
    • fischr
      I am trying to simulate a simplified diaphragm seal system. I used a command block to insert HSFLD242 Elements to model a fluid that is fully enclosed by solids (containing vessels) in a static structural simulation at 400°C. for some reason the coefficient of thermal expansion for the fluid is not taken into account during the simulation .
      This is the command snippet i used to model the fluid:
      fini
      /prep7
      *get,typemax,ETYP,,NUM,MAX    ! max defined element type
      *get,realmax,RCON,,NUM,MAX    ! max defined real constant
      *get,mat_max,MAT,,NUM,MAX     ! max defined material
      *get,nodemax,NODE,,NUM,MAX    ! highest numbered node in model
                         ! Create a new higher number for element type, real, and material
      newnode=nodemax+1000          ! number for pressure node for HSFLD242
      newnumber=typemax+1
      *if,realmax,ge,newnumber,then
         newnumber=realmax+1
      *endif
      *if,mat_max,ge,newnumber,then
         newnumber=mat_max+1
      *endif
      et,newnumber,HSFLD242         ! 3-D Hydrostatic Fluid Element
      keyopt,newnumber,1,0          ! UX, UY, UZ, plus HDSP at pressure node
      keyopt,newnumber,5,1          ! Fluid mass calculated based on the volume of the fluid element
      keyopt,newnumber,6,1          ! incompressible
      tb,fluid,newnumber,2,,,liquid ! Liquid Properties
      tbtemp,20.0
      tbdata,1,1800,9.71e-4,9.36e-7 !Bulk modulus,coefficient of thermal expansion,density
      tbtemp,400.0
      tbdata,1,2000,1.86e-3,5.48e-7 !Bulk modulus,coefficient of thermal expansion,density
      r,newnumber
      type,newnumber
      mat,newnumber
      real,newnumber
      cmsel,s,bro                   ! Select nodes on interior
      esln                          ! Select elements that touch these nodes
      n,newnode,0,0,7.2          ! newnode as pressure node for ESURF of HSFLD242
      ESURF,newnode                 ! ESURF HSFLD242 elements over solid element faces
      allsel
      fini
      /solu
      I am simulating at an environment temperature of 400°C so that the thermal expansion of the liquid and the solid has to be considered. But if i simulate with different coefficients of thermal expansion for the fluid, i get exactly the same results for the stresses in the component, although they should differ due to different thermal expansions.
      I changed the material properties for the fluid from this:
      tbtemp,20.0
      tbtemp,400.0
      to this:
      tbtemp,20.0
      tbtemp,400.0
      tbdata,1,2000,3.0e-3,5.48e-7 !Bulk modulus,coefficient of thermal expansion,density
      however, the results for stresses are exactly the same. Do i need to set up a zero thermal strain reference temperature for the fluid material data ? why is thermal expansion not taken into account for the fluid ?
      Thanks for your help.
    • fischr
      here is a picture of the component. the HSFLD242 elements are unfortunately not displayed in workbench:
