June 19, 2022 at 8:27 am
valparadiso12
SubscriberHey,
I would like to change the turbulence intensity of my fluid (water) when stirred in a tank. However, I can only find this option when I have an inlet defined, for example, a gas inlet.
Does somebody know where I can change the turbulence intensity in a single-phase simulation with no inlet? So to say, the turbulence is only introduced through the agitation.
Thank you for your help. -
June 20, 2022 at 8:16 am
Ansys EmployeeErm.... The boundary condition value is there to give the solver a number when material enters the domain. The turbulence values (k, e, w, etc) are then calculated based on the geometry, flow field etc. As you don't have a boundary value you're starting the model off from initial conditions: setting k, e (or w) as 0.01 isn't unreasonable.
3730
2570
1783
1236
594
