Changing contact types between load steps
    • twata
      How can I change contact type between load steps during an analysis? For instance, I want to have a bonded contact during the 1st load step and change it to frictionless in the 2nd load step.n
    • Chris Quan
      In Ansys 19.0 and later, one can right click on the analysis branch in the Outline and insert a Contact Step Control. Then create both contact types in the model, bonded and frictionless with the same scoping selections. nUse the Contact Step Control to activate the bonded contact in the first step (alive) and kill it in the second load step (dead). Use another Contact Step Control to deactivate the frictionless contact in the first load step and activate it in the second load step. These status changes are done in the table of the Contact Step Control, to the right, not in the Details of the feature. nIn Ansys 18.2 and earlier, it has to be done entirely with command snippets. The ekill and elive commands can be used. Insert a command snippet under a contact with lines like these: nmcid=cid nmtid=tid nThen under the analysis branch, insert a command snippet with lines like these: nesel,s,type,,mcid nesel,a,type,,mtid nekill,all nallsel,all nOne can set the load step for which the command snippet applies in the Details.n
