Changing coordinate system in construction path not possible?
    • Tobias Zeller
      Hey everyone,
      I added via construction geometry a path to my project. The path type should be "two points" which I want to edit with a cylindrical coordinatesystem (cs). Unfortunatly I'm not able to change the coordinatesystem for start or end point at all.
      But I'm able to change the cs for path cs.
      Is that normal or do I overlook something simple?
      Best regards
    • peteroznewman
      Path construction geometry only supports a Cartesian csys and does not support a Cylindricial csys.  This is normal.
