Changing inlet conditions on the fly in batch job
    • Dioser
      Hey everyone,
      I am trying to run a batch job where I let the solution converge for some inlet velocity conditions and incrementally change the flow direction (by changing the velocity components). The goal is to get data for many angles of attack on a 3D aircraft wing.
      I was able to set up the batch job and get data for different angles of attack by changing the flow direction manually in the GUI when creating the Fluent case, but that is time consuming for many studies. Currently, my Ansys input file is the following:
    • Keyur Kanade
    • Dioser
      Thank you for the suggestion, but I found an alternative way of doing that in the command prompt, so I set up an input file such as the one below, and it works:
      I hope this will help anybody who wants to do something similar.
      Best Dioser
