Ansys Products
Ansys Products
Changing license preferences for HFSS running on SLURM
    • vatalogg
      Hello everyone,
      I am trying to run an HFSS simulation on Scinet (https://www.scinethpc.ca/) that runs an SLURM scheduler. The version is 2020/R2. Licenses are provided by CMC.ca. Due to a recent update they moved to the Pro, Premium, Enterprise Licenses (the old "legacy" ones are not supported). So, they recommend to:
      a) Check the use PPE product licensing in the General>Desktop Configuration option
      b) Use Pool as the HPC License in the "HPC and Analysis Options".
      I have put these settings in the GUI (and they seem to be saved if I reopen it), but I submit the jobs through SLURM, So, I read that there should be some SBATCH options. Here is what I use:
    • ANSYS_MMadore
      The issue isn't the hpc licenses but the solver license which needs to be told to use the new PPE. You can add this to the command line: -UseElectronicsPPEnOr you can add this to the Options File.nDesktop/Settings/ProjectOptions/UsePPELicensing=1 nnThanks,nMattn
    • vatalogg
      Hello Matt nnThank you a lot. This solved the problem and simulations now work.nnBest regards,nVasilisn
    • CMCsupport1
      Hello, Mr. Madore, nAnother part of this issue was the licence server address: n License path: 6624@lmserver-6.cmc.canThis is no longer correct. Staff at SciNet (UToronto) fixed the script that pointed to the CMC Microsystems' Ansys server (Feb. 9th, 2021), replacing this older port@server address with the current port@server address. nAdding this to thank the SciNet staff members for their help.Regards,nCMC Microsystems Technical Support staffnn n
Viewing 3 reply threads
