August 25, 2023 at 2:25 pm
Matthew Little
SubscriberFor RAM reasons, I need to run my model using the iterative solver instead of direct. The iterative gets through the anlaysis, but very slowly since the Limit is set to 1E-8. Need to run numerous analyses with 20+ steps in each so running it this way is time-prohibitive.
How can I change the Limit the iterative solver uses as convergence criteria? I would like to try to set it to 1E-7 to see how much quicker it takes to run.
August 28, 2023 at 10:21 am
Aniket
Ansys EmployeeIt would not be recommended to change these settings and rather keep them as default. Please check the following thread for more information:
Understanding Force Convergence Solution Output (ansys.com)
-Aniket
- License Error
- Workbench not opening
- Workbench error
- how to open DesignModeler
- FlexNet Licensing – Not running
7592
4438
2951
1427
1322
