Changing multiple boundary condition parameters in one UDF
    • JaySmall
      I'm trying to write a UDF to switch between different velocities along a velocity inlet based on pressure conditions at the boundary cell. I have the velocity profile DEFINE_PROFILE portion of the UDF sorted, but I am curious: can I change the static temperature in the thermal tab using the same UDF, or do I need to write another DEFINE_PROFILE section for this temperature change?
    • Karthik R
      Administrator
      Hello:
      You can have this code in the same UDF file. However, you will need to use the DEFINE_PROFILE macro again.
      Karthik
