February 28, 2017 at 9:57 am
Nikita
Ansys EmployeeHow to change the automatic partitioning method in parallel?
March 21, 2017 at 11:57 am
Vishal Ganore
Ansys EmployeeIn the parallel solver, unless the area is divided beforehand by manual partition, automatic partitioning is executed when case file is read. The division method in automatic partitioning by default, will run the Principal Axes (Metis in R14.0 and above). A TUI command can be used to change the division method before reading a case file. Example: When partitioning method is cartesian-x /parallel/partition/auto/method cartesian-x
Trending discussions
Top Contributors
2610
2088
1319
1108
459
Top Rated Tags
