Changing tolerance for Boolean operations?
    • pgl
      How can you change the tolerance for boolean operations?
    • Arun
      Check the default value of tolerance for boolean operations through BTOL, STAT command. Provide a tolerance value about 1/20th to 1/10th of the minimum KPT distance using the BTOL, tolerance value
