TAGGED: antenna, antenna-design, antenna-efficiency, antenna-parameters, antennas, hfss, hfss-15, HFSS-Ferrite
October 13, 2023 at 4:43 pm
October 17, 2023 at 3:04 pm
Praneeth
Ansys EmployeeHi Imtiaz,
Thank you for reaching out to the Ansys learning forum.
It is possible to edit the trace name. Please select the trace in the Project Manager window > in the properties window check Specify Name > enter the desired name.
For more information on creating and modifying reports, please go through the "Post Processing and Generating Reports" chapter in the HFSS help pdf document.
Best regards,
Praneeth.
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Concept of Interpolation Sweep in HFSS
- Error
8808
4658
3151
1680
1470
