December 22, 2022 at 5:45 am
iqnlo
SubscriberHi guys
I am following this instruction to analyse the mode in the silicon waveguide.Optimizing waveguide geometry for single-mode – Ansys Optics
I would like to modify it and see the n_eff at other wavelengths. However, even if I changed the wavelength at here:
The wavelength will automatically change to 1.55um when I start the parameter-sweeping process.
May I ask how to fix this problem and let me simulate the modes for other wavelengths?Thank you so much!
December 22, 2022 at 3:56 pm
- Error on Lumerical device
2524
2066
1279
1096
459
