Characteristic impedance of a dielectric waveguide extraction problem
    • xuanding
      Hi all,
      I try to simulate the characteristic impedance of a Si dielectric waveguide (Thickness x Width: 500um x 300 um) with wave ports.
      • Ports were set to Zwave and "Do Not Renormalize"
      • Port Zo(1,1) is supposed to be the characteristic impedance of the dielectric waveguide
    • AndyJP
      Sorry. Was thinking about more complex thing. Well, yes for a simple waveguide it should be Z11.
    • xuanding
      The curve in the figure is not Z11. It is Port Zo(1, 1). When Wave port is matched, I think its port impedance should be the characteristic impedance of a uniformed waveguide.
    • AndyJP
      The result may be related to the wrong expectations about the fundamental mode.
      Try defining a wave port with a mode (integration) vector. Or at least examine the field distribution carefully. These notches look like flips to higher order modes.
      If results are still confusing, the dispersion and characteristic impedance problems are well analyzed by the eigenmode solver.
    • xuanding
      Thank you for the advice.
      I have tried wave ports with integration lines, and it gives me the same curve, but without spikes. The E field distribution looks normal. Some similar tests were done in ADS (Advanced Design System) by exporting a S2P file, and the impedance for fundamental mode in a Si waveguide is around 120-150 ohms at that frequency range, which I think is a reasonable number.
      For the eigenmode solver, I'm a little curious how to check the characteristic impedance. The quality factor and resonator frequency are defined in the results, but I haven't find other parameters. Could you please direct me how to test Z0, or share with me some related materials? Thank you again.
    • AndyJP
      100%, the spikes are higher order modes crossing the fundamental mode. With the field vector you lock the mode and filter them out.
      So, the results should be correct for your model and setup.
      For better understanding, you should make an eigenmode section of your waveguide, and sweep the phase in order to see the dispersion, which will give you a hint on impedance. If it is bent somewhere, that will be the answer.
      Don't forget that when no boundaries of the model are defined for "airbox" in HFSS, PEC condition is used. You should define some radiation and move the boundaries far away.
    • xuanding
      Hi Andy Thank you for the detailed instruction.
      You are correct on the "spike" issue. I have updated my simulation setup.
      I also tried eigenmode simulation. I'm able to obtain resonate frequency and dispersion, but have no clue to the characteristic impedance.
      The characteristic impedance of microstrip line and metallic waveguide is able to extracted with drivenmodal collaborating with wave ports. And It was capable to simulate correct Z0 of dielectric waveguide using drivenmodal in HFSS 2019 R2 or older versions. However, I can't prove it now since our license doesn't support older versions due to "Electronic Pro, Premium, Enterprise product licensing". I think it is just data processing difference in 2020 R1, R2 and newer versions.
    • AndyJP
      you can not get it from dispersion only. you need a field solution. But you can see the peculiarities. Where the dispersion is straight, the impedance is a flat ratio of phase constants. Where it bends, the impedance will also go up and down.
      We also upgraded from 2020R1 to 2021R1, and i see no differences, only improvements (like better lumped ports handling, other new features)... and recalling earlier versions, I see nothing broken, except legacy scripting commands disappeared.
    • AndyJP
      P.S. you can take just the old license file to start the earlier version, and check, then put it back.
    • xuanding
      We are using a license server and the old license has expired.
    • xuanding
      The problem is figured out.
      In HFSS 2020 or newer version, the simulation configuration for waveguide impedance is a little different from the older versions.
      Drivenmodal
      Proper wave ports, do not renormalize
      Port type: Zwave
      Frequency sweep type: Discrete
      Then port impedance Zo(1,1) would be the waveguide impedance.
    • cbiurrun
      Dear Andy I was trying to compute the characteristic impedance of a Coplanar Waveguide with the Fields calculator using the Fields computed in an Eigenmode Analysis but I am not much familiar with the calculator tool. I was trying to compute the Zpi impedance, but I keep receiving errors when I try to obtain the P and the I (also, I am not sure if I should take Jsurf, Jvol or Jm for this computation). Could you maybe give me some hints on how to achieve this? Thank you!
    • AndyJP
      Getting an impedance of a complex structures with the field calculator only is a hard task. I use it for comparative study, but do not rely on absolute result values.
      You have a waveport, which is a 2D model of the infinite line. So HFSS should offer you the impedance of your choice automatically. However.... well, it may be not what you expect, since it is not a true TEM mode there. But it may be the thing you need for matching. Then, you can either achieve a perfect matching with your DUT, and suppose the port impedance equal to the equivalent char. impedance, or pull it out of Z or S parameters by Colin.
    • cbiurrun
      Hi again Andy, thanks for your quick reply.
      When you have a, for example, Driven Modal analysis, yes, you have a Waveport and, in its definition, you are able to choose which impedance you want HFSS to calculate.
      However, in the Eigenmode Analysis, you don't have any port. You have basically some info regarding dispersion (a relationship between Omega (i.e. complex frequency) and Betta (phase constant) and the Fields calculated for each mode.
      What I was trying is to make a comparison between the impedance offered by HFSS when using a waveport and the impedance calculated from the Eigenmode solver for each mode, but I am not able (or better said, I do not have the knowledge of the tool) to calculate this impedance with the Fields Calculator.
    • AndyJP
      Ah, yes, that's why you use both, Eigenmode and DrivenModal. One for dispersion, another for the impedance. The wave impedance definition of Sexh*/Shxh* works well for TE(M) in a straight guide, and only along the poynting vector.
    • cbiurrun
      The Fields Calculator would not let me do that. If I take E and H and try to make the Cross Product, I get an error. Also, how can I make the H*? Should I take the real and imaginary parts individually?
      Thank you
Viewing 15 reply threads
