Tagged: 50-ohms, characteristic-impedance, transmission-line
July 31, 2020 at 1:08 pm
Karthik R
AdministratorWhy the characteristic impedance of RF transmission lines is 50 Ohms?
prajput
Ansys Employee50 ohms is the trade-off between power and losses. maximum power transfer is at a peak at 30 ohms but attenuation or losses are minimum at around 77 Ohms. So, 50 ohms is selected as standard as the trade-off between losses and power.
July 31, 2020 at 1:09 pm
Karthik R
AdministratorThanks for the reply ?, I wonder how the characteristics impedance of microstrip line is determined?
prajput
Ansys EmployeeHi @Kremella,
The Characteristics impedance of the strip line depends on the width of stripline, substrate material, and height.
- What is the difference between internal and external flows?
- How do you define specific gravity? What is its significance???
- Why is it much easier to roll a log than drag a wood cube with the same mass?
- The level of water inside the straw was higher than the level of water in the beaker
- What is the surface tension of a fluid?
- How to gain research experience?
- Whats the difference between sensible heat and latent heat?
- Cell Counting?
- Why does the total sum of forces acting on a system always have to be equal to zero?
- Why ice floats on water
2706
2142
1357
1144
462
