March 13, 2021 at 8:13 am
Abubakar
SubscriberI am doing CHT analysis on exhaust port the velocity is not constant along the pipe. So what should be the velocity and characteristic length to be considered for calculating y+?n -
March 15, 2021 at 6:27 am
Keyur Kanade
Ansys EmployeePlease have a look at nhttps://us.v-cdn.net/6032193/uploads/E91NTXZUKD7K/cells-png.pngDear all,I'm new to CFD. Can some suggest me the characteristic length for this geometry if one the cell is emitting gas and it travels through the voids?https://forum.ansys.com/discussion/21478/charcterisitc-length
Regards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn -
March 15, 2021 at 12:28 pm
March 15, 2021 at 1:21 pm
Kalyan Goparaju
Ansys EmployeeHello Abubakar, nSince you mention that the flow is through a pipe, I would perhaps use the pipe diameter as the characteristic length. As for the velocity, perhaps average velocity on the exit plane is a good starting point. nThanks,nKalyann -
March 15, 2021 at 1:56 pm
Abubakar
SubscriberThank you sir n -
March 15, 2021 at 2:58 pm
DrAmine
Ansys EmployeeYou just need to use an eligible relationship for skin friction which is valid for internal flows if you have that.Tips & Tricks: Estimating the First Cell Height for correct Y+ | Computational Fluid Dynamics (CFD) Blog ? LEAP Australia & New Zealandn -
March 15, 2021 at 3:23 pm
Abubakar
SubscriberThank you Sirn -
March 16, 2021 at 1:00 pm
DrAmine
Ansys EmployeeWelcome n
2564
2080
1293
1106
459
