April 28, 2023 at 4:27 am
JINBO Mi
Subscriberhallo, dear specialists, i am a new PHD students, i have to do the research about charged powders in the electrical field, i want to make a simulation about the flow of the powders in can, which software would like be a good choice, please help, dear specialists, thanks for all of your kindness.🙏
May 16, 2023 at 1:06 pm
Murari Iyengar
Ansys EmployeeHi, you can look at using Ansys Maxwell and/or Rocky to do this. Depending on your requirements, you can also try coupling it with Fluent if required.
May 16, 2023 at 3:30 pm
JINBO Mi
Subscriberthanks for your kindness, I found it is difficult to run ANSYS, i have checked my pc, but it do not work, maxwell have stopped and pc stop work😂, finally i have removed all of the software, i have to say good bye to the software, thanks for your kindness, good bye, my dear specialist.
- Maxwell, HFSS or Q3D?
- Error
5162
3255
2443
