Preprocessing
Preprocessing
Check Geometry Error in Spaceclaim
    • Sneh Patel
      I have this deformed geometry which I imported in SpaceClaim as stl file. I converted it into a solid. However, when I right-click on the 'Solid' in the structure toolbar on left side and 'Check Geometry'. I get these errors. How do I go about solving this? I need to save this as sat so I can open it in HFSS.
      Thank you,
    • Nikhil Narale
      You may want to check the 2nd point in this section of the documentation: Checking Geometry (ansys.com)
      If you are not able to access the link, refer to this forum discussion: How to access the ANSYS Online Help
      Thanks!
      Nikhil
