3D Design
3D Design
Check geometry
    • tarabehmanesh
      Hello
      I wanted to ask if there is a way to make sure the created geometry is watertight or dirty? (In spaceclaim, ansys 2021 R2) i used check geometry and no problem was found however fluent meshing says that i should use fault tolerant workflow.
    • Keyur Kanade
      Please check geometry in SpaceClaim.
      Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
      The geometry should be error free to proceed.
      If geometry has any errors, please modify/recreate geometry at those places.
