Check particle concentration at various location and effect of filter.
    • Subho
      Change of concentration due to purifier at various location is to be investigated, i.e. change of concentration or mass of pollutant (PM 2.5 and PM 10) at various locations(marked 1 to 6 in attachment). Purifier consists of filters and blower (details are in attachments). I have tried to simulate it in Ansys Fluent Version 19. For defining filter I made filter cell zone as porous medium with constant initial and viscus resistance. I have chosen DPM with constant surface injection.
    • DrAmine
      Can you insert the pictures instead of attaching them?nOn which locations you require the information? What about using DPM Sampling? What about using Report Definition and surface integrals?n
    • Subho
      Thanks again for your valuable reply. Now I have attached pictures if it is coming proper you can share your mail id I can send you.nThe desired location is numbered from 1 to 6 in picture. As suggested I have tried sampling but values are coming random and coming around constant in different case setup, also I don't have any control over time. For this case I have given time step of 30 seconds but it is giving result from flow time 900 s. nIn report definition I am not finding option to calculate for at particular location. It is giving result for whole domain not for any particular cell zone or plane or point. nIn surface integrals I have not found any option regarding DPM nn
