Checking stabilization energy much less than 10% strain energy in buckling analysis – meaning
    • Gennaro
      Hello everyone,
      in the slides of Ansys (attached) I read that, after the simulation, I have to check if the energy dissipation ratio (EDR) is greater than the EDR initially specified (slide 39).
      How can I do that? In the slide 43 the suggested check is:
      max stabilization energy << 10% strain energy
      This means that the strain energy coincides with the potential energy mentioned in the slide 39:
      EDR = (stabilization work) / (potential energy)
      Thank you in advance.
    • peteroznewman
      Does it clarify things if you know the following equality?
            Potential Energy = Strain Energy
      I think the slides introduced unnecessary terminology when they added potential energy. It would be clearer if the slides stayed with strain energy.
      EDR = Stabilization Energy / Strain Energy.
    • Gennaro
      Hello Peter,
      I know the equality (I found it in many books; e. g. "The Finite Element Method and Applications in Engineering Using ANSYS® - Erdogan Madenci, Ibrahim Guven 2nd Ed"):
      Maybe your equality is valid in special cases. If you know any paper or book where I can find your equality, give me its name please because I need to explain my sentences to my professor.
      Thank you a lot.
    • peteroznewman
      Here is the ANSYS definition of Element Potential Energy, which for an elastic analysis is Strain Energy.
      There is a separate quantity for Work Done by External Loads.
      There is also Kinetic Energy, but for a Statics / Linear Bucking, there is zero velocity.
    • Gennaro
      Hello Peter, thank you for your reply. Can you tell me where you took the above paragraphs please?
    • Aniket
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/ans_thry/thy_tool16.html
    • Gennaro
      Hi Aniket, I am not able to open your first link. Can you tell me what is it please? If you write the key word you inserted in the help, I can find it.
    • peteroznewman
      If you are using ANSYS 2019 R3, then do this.
      1. From ANSYS Workbench, use the menu Help > ANSYS Workbench Help.  A browser window will open.
      2. In the post that has a link to the ANSYS Online Help, Right Mouse Button on the link and select Copy Link Address,
      3. Go to the browser window that opened in step 1 and Paste in the address bar and you get to the required page.
    • Gennaro
      Perfect step by step solution. Thank you very much.
Viewing 8 reply threads
