Ansys Products
Ansys Products
CHEMKIN creslaf_user_routines file
    • ayse korucu
      Hello There,
      On teaching purposes, I have been trying to modify the CHEMKIN creslaf_user_routines file to set new BC and ICs. Even though I did the necessary changes in the related FORTRAN file I can't make it to use new set up. Could anyone gimme a heads up on this matter?
      I suspect that CHEMKIN somehow keeps using the previously created data.
      Thanks,
    • Judy Cooper
      Hi Ayse:  Unfortunately the scope of this question is beyond what can be handled on this forum. It sounds like your code is not linking correctly, however.
      I would suggest trying some of the sample code that comes in the Chemkin installation, and consulting the Chemkin API manual on the steps required to compile and link user-routines:
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v222/en/chemkin_api/chemkin_api.html
    • ayse korucu
      I already did what you suggested. I have exhausted all the possible solutions for the regarding problem already.
      So could you let me know which channel I need to use to solve this issu then?
