Chemkin Pro hydrogen combustion
    • Elisa
      Hi all :)
      The model fuel library manual for Chemkin Pro says that the hydrogen chemistry set (hydrogen MFL2020) forms the core of all full mechanisms. Please can anyone confirm if the rate coefficients shown in the Hydrogen NOx MFL2020 are the same as in the Diesel four component MFL2020 mechanism, as this file is encripted so I can't check.
      many thanks for any help in advance
    • Judy Cooper
      Hi Elisa:
      The H2 NOX mechanism is more complete/detailed than what you would find in the encrypted diesel mechanism.
      A lot of fuels get broken down into smaller molcules via reactions that are triggered by H atoms, so the small-molecule h2 reactions are shared by most hydrocarbon combustion mechanisms to some degree, but they can proceed at slightly different rates in different environments. Also, some steps may not be present in the larger mechanisms because they are not as critical to the overall product formation rates as they are in pure H2 combustion. H2 combustion is always a key reaction step in any hydrocarbon oxidation, however.
    • Elisa
      thank you Judy :)
