April 29, 2021 at 2:21 am
April 29, 2021 at 7:14 am
Naresh Patre
Ansys EmployeeHello Rain Huang
If you check the error message, it says that the conducting Non-slip wall (or the fluid solid interface) also has Temperature 10 defined on it. You cannot define boundary conditions (BC) on the interfaces. So you will have to delete the Temperature 10 located under Solid thermal section of the physics setup. If the fluid is having a temperature of 80deg, then you can edit the Flow Inlet BC and specify the temperature there.
Please check out the getting-started tutorials on CHT at below mentioned link:
April 29, 2021 at 7:40 am
rain
SubscriberHello Naresh Patre
Thanks for reply. I understand that I can't set temperature on the interfaces. I would try other method to add heat source.
3744
2570
1789
1236
594
