Discovery Import
Discovery Import
CHT Region(s) troubleshoot
    • BhaskarModak
      Can anyone help me with this air heater CHT problem  ? The air is supposed to be drawn through the upper channels and sent out through the bottom outlet.The flux is to be set on the top channels and plate. The siulation works perfectly fine with only fluid flow template. But with CHT, the errors show the 9 regions have more than one region interface. If anyone can provide me with a detailed workflow pdf of the steps, that would be very helpful. Thank you.
    • Naresh Patre
      Hello Bhaskar Please check out one CHT example posted at below mentioned link. https://ansyskm.ansys.com/forums/topic/discovery-aim-application-examples-fluid-solid-heat-transfer-cht// Regarding the issue related to region interface, please check out below article: https://ansyskm.ansys.com/forums/topic/156426/
