Circular plate – Shell meshing
    • Lovisa Svanborg
      Hi!
      I have problem to split a circular plate and then do shell meshing. Firts how can I split a circular plate with a inner circle. I want to split so both side has a inner circle. Then I want to make midsurface and select share. It did't work to share.
      Regards Lovisa
    • Aniket
      can you insert a few images explaining your question in more details?
      -Aniket
    • Lovisa Svanborg
      First I want to split a circle with another inner circle. I am not sure I did right, if it split. Then I want to add midsurfaces. When I did two, I couldn't share both, just one midsurfaces. This is because the plate is thin and I want to use shell elements. So I want to split correct, and create midsurfaces (I thoght inner and outer circle) and be able to share.
      Lovisa
    • Lovisa Svanborg
      It is solved now!
      Lovisa
Viewing 3 reply threads
