January 27, 2022 at 3:20 pm
mwhitby
SubscriberHello, I'm trying to look more into how FDE solver works and I'm following this link. https://support.lumerical.com/hc/en-us/articles/360034396734-FDE-solver-analysis-Mode-List-and-Deck
My questions are:
- What does lambda_0 represent (As in the E(z) equation)?
- What does k_0 represent (as in the neff formula)?
- What does n represent (As in E(z) equation)?
Thanks!
January 27, 2022 at 5:48 pmGuilin Sun
Ansys EmployeeWe know that for any mode, it has an eigen frequency and wavelength. so
lambda_0 is the wavelength in vacuum;
k_0 is the wave number , 2Ipi/lambda_0;
n is the real part of (effective) refractive index.
January 28, 2022 at 12:54 ammwhitby
SubscriberThanks!
- Error on Lumerical device
3744
2573
1821
1236
594
