Ansys Products
Ansys Products
Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
    • dhr999
      I installed Ansys for x64 architecture and my computer has the same architecture, everything works fine just when I try to open any design exploration application it shows this error:
      "Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))"
    • tsiriaks
      Please post the entire screenshot of the error.
      Do you have any .err files under (default) C:Program FilesANSYS Inc  or  C:Program FilesANSYS IncANSYS Student
      Please also post the output of 'set' command (without quote ' ') from the CMD Prompt.
      Thanks,
      Win
    • dhr999
      Hi tsiriaks.
      I uninstalled the version of ANSYS Student which I had and downloaded the latest files from the website.
      Now Workbench wont open at all. It says
      I tried the cmd commands you gave in the following thread:
      https://forum.ansys.com/forums/topic/ansys-19-1-fatal-error/
      But the result was the same. Also there are not any .err files present and I have the environment variables set too.
      Can you please help me?
      Thanks
    • tsiriaks
      Open a regular CMD Prompt, then issue the following command
      move %appdata%ansys %appdata%ansys.back
      If this still doesn't work, post the output of the 'set' command
    • dhr999
      That didn't work:
      The output of set is:
      Output of Set
      Please can you add the text/image into the post: staff are not permitted to download/open attachments or links.
    • rodmarti
      Thank you tsiriaks !
      Changing the appdata folder solved the issue for me.
      However, when I close Workbench, the error occurs again the next time I open it. It wouldn't be a problem, but I have to install all my extensions again.
      The other problem that occurred when I changed the appdata folder is that I can't see the icons in the model tree in mechanical (I am sending a picture). I am not sure if the problems are related, but I am sending anyway.
      What can it be?
      Thank you guys in advance!
      Rodrigo
    • tsiriaks
      Hi Rodrigo,
      Please create a new thread for your own inquiry.
      For this
      "Changing the appdata folder solved the issue for me. However, when I close Workbench, the error occurs again the next time I open it. It wouldn't be a problem, but I have to install all my extensions again. "
      In that case, I would recommend to not rename the entire  %appdata%ansys folder, just try renaming the folder inside this one-by-one, and narrow down where the issue actually is, then you can just rename that file or the content of that file in the future. This will not affect other settings and ACT extension installation (unless they are the one that causes the issue).
      Removing %appdata%ansys folder should not cause issue with missing icons. Please create a new thread and we will investigate further.
      Thanks,
      Win
Viewing 7 reply threads
